Did you do the Z leveling? If the nozzle is just a tiny tiny bit too far from the glass then the filament will stick to the nozzle instead of the glass. If you *did* already do z leveling try pushing up on the glass during the first layer to see if that helps. If it helps then turn the 3 screws the same amount CCW to get the glass a little closer to the nozzle.
gr5 2,194
