reset the mm value by clicking the curved arrow, an other value overrides the %
- 5 months later...
I could also use more elaboration on this. I get the curved arrow to reset the values if I change Infill Line Density, but the arrow is not there to restore default values. I wish to be able to change infill density again without making a new profile. What do I need to change so it is no longer grayed out?
Press on the fx-icon in front of the Infill Line Distance value
Edited by Mari-
1
DidierKlein 729
Hi and welcome in the community,
You can change infill percentage, but in your case you have the infill line distance parameter that is overriding this value so you need to change this value in order to change the infill
JackAttackFilms09 0
Can you elaborate on this. How do you change it? Thanks!
