fabiok1995 0 Posted June 15, 2017 in Printing small parts with Ultimaker Nylon I am using an Ultimaker 2 printer with the transparent Ultimaker Nylon filament. As a test I was printing a small block with dimensions of 2x3x3cm at 100% infill. What I have noticed is that the inner volume of the block prints fine at any layer thickness (I tested from 0.04 to 0.3 layer thicknesses). As I decrease the layer thickness the quality of the outer surface/perimeter of each layer decreases. I believe the problem is that every time a new layer starts, it prints the outer perimeter of that layer extremely fast compared to when it is printing inside of that layer. This makes the nylon filament come out in blobs around the perimeter and not in a smooth extrusion which is seen when it's printing the inner section of the layers. It seems this problem is only fixed by increasing layer thickness, but I want to print at smaller layer thicknesses. What can I do? Is there anyway to change the speed when it is printing the perimeter? (Will be posting pictures of the printed piece in question tomorrow) Share this post Link to post Share on other sites
Labern 716 Posted June 15, 2017 in Printing small parts with Ultimaker Nylon what cura version are you using? Yes, you can change all those speeds. You need to go to custom settings. if you hover the mouse next to the speed menu you will see a little gear. Clicking on that will give you a list of all the setting which can be made visible. Select the ones you want then you can adjust any individual speed you want. Share this post Link to post Share on other sites
fabiok1995 0 Posted June 15, 2017 in Printing small parts with Ultimaker Nylon (edited) what cura version are you using? Yes, you can change all those speeds. You need to go to custom settings. if you hover the mouse next to the speed menu you will see a little gear. Clicking on that will give you a list of all the setting which can be made visible. Select the ones you want then you can adjust any individual speed you want. I was using and old Cura version, I will try with the most updated software and see if changing those settings help the print. Although I see that the default wall speed in most recent Cura software is at print speed 60 mm/s for the inner and 30 mm/s for the outer wall speed. I wonder why those speeds are set higher in the old software. Thank you! Edited June 15, 2017 by Guest Share this post Link to post Share on other sites
