2.6 error slicing when 'generate support' in extruder 2 PVA is selected. Or 2.5 building extra geometry. Any ideas?
Posted
· 2.6 error slicing when 'generate support' in extruder 2 PVA is selected. Or 2.5 building extra geometry. Any ideas?
First of all - "slice view" is your friend. Always look at your model in slice view. You can scroll through the layers and see which nozzle is being used when and it helps you realize problems and what slicer settings do.
If you click on the gear in settings (any of the gears) you can search for "tower" and enable those to be visible. Then you can set the position of the tower by changing x and y value in mm. Actually this is a case where "normal" view helps you position the tower. The back right corner is a bad location for this because the glass is usually lower there. Best to put it near the rear screw.
The tower is optional and some people don't use it but I personally prefer it. You can just uncheck the tower option if you want. The tower basically wipes the nozzle when you switch nozzles.
gr5 2,210
