Help TweakAtZ 5.1 Cura 2.5.0 Not working
bmht
Posted · Help TweakAtZ 5.1 Cura 2.5.0 Not working
I got a calibration cube 2 cm by 2 cm
Unders Xtensions->Post Procesing->Modify Gcode I add a script and select TweaAtz 5.1 (Experimental)
I select Trigger at Height
Tweak Height = 10mm
Behavior = Keep Value
No Layers = 50(since each layer will be 0.2mm and I got 1 cm height for a set temperature = 100mm / 0.2mm = 50)
Tweak Extruder 1Temp = selected
Extruder 1 Temp = 210
Now for the second part
Tweak Height = 10mm
Extruder 1 Temp = 200
But it prints the WHOLE cube at 210
Any ideas???
Thanks
    Come one guys no one knows how to change settings based on height?
    There must be someone who does Help here?
    Thanks
    It is marked as Experimental, so you may have uncovered a bug.
    What printer and gcode flavors are you using?
    What is your Initial Layer Height? If its .3mm, then perhaps the Tweek is not triggering because the layers would skip over 10mm exactly: 9.7mm / 9.9mm / 10.1mm / 10.3mm
    Not sure, haven't looked at the code for that plugin.
    Hi
    I think this is a very powerful feature
    It will allow in theory to allow you to modify many features by the height.
    My initial layer is 0.3mm
    Using a Tevo Tarantula
    Thanks
    TweakAtZ has been ported to Cura 2.x but it might well be it has problems with the Griffin flavor of the UM3.
    As the Cura devs think the current code base is not well structured I already suggested to implement the functionality into Cura itself and make TweakAtZ obsolete.
