What if you do a manual leveling to get the build plate closer to the nozzle and then attempt an automatic leveling?
Thanks for the suggestion, but I have already tried that before posting it here (FWIW: I have already tried all options available).
The only way that I can get the bed to close vicinity of the nozzle is when I raise the bed using UM3's menu. All other options leave me with a huge distance, effectively rendering my machine as inoperative.
Any other suggestions, anyone?
I would reach out to your reseller as they should have better troubleshooting or if it is a defect with the printer would be able to offer service/replacement.
kmanstudios 1,074
The first step is to use the front turn wheel which moves the buildplate via the Z-Axis screw. The buildplate screws are just for fine tuning. And, for me, I have found they need to be a bit loose as in, not fully up or down, but in between to allow for small deviances and bounce in the plate during printing.
But it always starts that far apart when doing a manual leveling.
The issue I am having is that the distance of the build plate to the nozzle is well over 10 mm, which simply is too much to compensate for by the screws when leveling the bed. As expected, the Z-axis offset calibration did not bring success.
When exactly do you see the 10mm distance?
Is that right after you start manual leveling?
Please try the following. Enable Active Leveling (set frequency to 'every print'). Then start your print job.
If you see a problem, please describe what you see.
- 2 weeks later...
This mystery is gone after I did another firmware upgrade to v. 3.7.x.
I still have no clue what happened, but am glad I am in business again
Thanks to all for your ideas, I very much appreciate that!
Zwakie 21
Two days since posting without any reaction, is it time to get really nervous now?
Anyone care to help me out?
