Ahoeben, I am using a custom 2ft x 4ft prusa printer I built. I will try you fix and post back. THANKS!
Edited by GuestI tried putting that py file into the directory you stated and overwriting the one that was in there. There was no difference. Do you have any other suggestions? If not I guess ill be trying to find older version of Cura. I think i was using 15.4, if memory serves correctly.
In that case it might be another bug.
The workarounds you mention in the opening post should work though.
ahoeben 2,047
Are you using a "Custom FDM Printer" with a single extruder? There's a known bug in 2.6.
I have heard there should be a 2.6.1 shortly. In the mean time you can fix it locally:
* Download this file: https://raw.githubusercontent.com/fieldOfView/Cura/adc547fa36b3edc288369543d1c97c648f6f22c5/plugins/CuraEngineBackend/StartSliceJob.py
* Replace the file on your computer that is located in [cura install location]/plugins/CuraEngineBackend (eg: ```C:\Program Files\Cura 2.6\plugins\CuraEngineBackend\StartSliceJob.py``` on windows)
* Restart Cura and test if it works now.
Note: this will only help you if you are indeed using a "Custom FDM Printer" with 1 extruder.
