Hey Nallath, thanks for that... unfortunately I tried disabling all firewalls and virus/malware protection and still no luck!
Hi Tim, I had a similar issue. I got it running ok, but not sure how! It was either uninstalling both Cura 2.5 and 2.6, then re-installing OR uninstall Cura 2.6, re-install it using a programme that records all file and registry changes (I used AShampoo Uninstaller, but there are many out there), then uninstall it with that programme. This removes far more changes than the regular uninstall. After that a regular Install woked fine. Needless to say make sure you have profiles, machines etc backed up before hand, they will disappear!
nallath 1,125
Perhaps your virus scanner is getting in the way? Some scanners seem to think that Cura is a trojan, so it could be blocking it.
