These prints are pretty good. Difficult to improve.
The robot has many overhang spots and of all of them, only one had the problem (circled). That part of the robot is very difficult to print because it is hanging in mid air when it prints that spot.
Whatever settings you used for the robot were slow enough - especially the antennas on the top - those look great so you must have printed them very slowly (the antennas). I don't think you can make the robot any better than that.
The other issue is more of a slicing issue. When the printer is printing *almost* level surfaces such as the top of a sphere, .2mm slices are more noticeable. This can be improved with .1mm slices. You can probably also double your speed if you slice at .1mm as the plastic will be coming out slower. But don't speed up your print so much that you have less than 10 seconds or so per layer as you will have other issues - especially with overhangs. It's critical that a lower level cool to a solid before adding the next layer. Especially for overhangs.
Next I predict you will have problems with warping when you print large parts. When you do, we will have solutions for you! Good luck.
illuminarti 18
Welcome!! Those are pretty nice first prints, well done! But yes, there's always room for improvement.
What temperature are you printing at? To get better overhangs - reducing the droopy bits on the robot - you generally want to print slower, and cooler, and be sure the fan is on.
Where the prints have some gappy parts, that may be due to under-extrusion - not laying down as much plastic as you should. Increasing the temperature might help a bit, as might slowing down a bit. You also need to make sure that you are using the right filament diameter when you slice the object. Do you know the exact diameter of your filament? Cura defaults to 2.89mm I think, but that's rarely the right size - most commercial filaments tend to be 2.85 or even 2.8 in most cases. If that's the case with yours, then you'll be extruding less than you should, because Cura thinks that every mm of plastic that gets fed in is thicker than it really is - and that's how it controls how much gets extruded out of the nozzle.
As you can see from those two statements... there's no one 'right' print setting; you have to adjust for the object you're trying to print. There are competing needs of temperature, speed, and layer height that effect the end quality.
You might also check the tension on your extruder drive spring. The spring should not be fully compressed - on mine, there is about an 11mm length of spring between the body of the extruder and the head of the spring. Check the filament in the bowden tube after a print.... it should have clear teeth marks in it from the drive bolt, but not be chewed up or worn.
The 'normal' settings in Cura are a good starting point, so I'd continue to tweak things around those settings while you get the printer bedded in and understand it better - and get a feel for what sort of settings an object needs. If you have problems, it's tempting to think that the 'High Quality' settings in Cura - slower, thinner layer heights are the solution. And really they aren't. It's not higher quality in the sense of fixing problems, but rather just improving the finish - less obvious layers, and better handling of 'almost horizontal' slopes and curves. Even on 'normal' quality, with 0.2mm layers, you should be getting perfectly good results. If you aren't, then keep posting here and lets try to tweak the hardware and settings until you are.
Well done on getting started though! Those are some pretty nice first prints - you should be pleased!
