The PPA is not officially suported. It could well be that there are things there that are not correct. If you want to play it safe, download the appimage (as that configuration of packages is actually tested by our QA team)
Could you give me your logs? That might show a bit more as to what is going wrong.
asb 7
Thopiekar's stable PPA has now Cura 2.6.1. Did an update.
Printer is connected to the switch:
Printer is visible in Cura:
Printing via Ethernet results in various errors:
Simply no luck :(
