Actually I think I am being misled and the problem is simply the bed is slightly too high for the first layer. This gives the impression of blobs but might be because the bed is blocking the nozzle too much. I will try adjusting.
kmanstudios 1,120
oh...I had assumed by "Manual Extrusion" that you were using a "Move function" to force the material through while not printing.
My mistake...sorry
kmanstudios 1,120
Have you cleaned your cores with a hot pull or atomic pull? The curling sounds like gunk in the core.
Also, what material? Is it hydroscopic?
