Same story here except my windows version is 8.1.
Cura 2.5 worked fine.
I had tried an earlier version of cura 2.6 and it didn't work either, so when I saw that 2.6.2 had been released, I tried again but no luck.
I get no errors, I click on it and see the splash screen and then it just stops executing and disappears from memory.
nallath 1,123
Did cura 2.6.0 or 2.6.1 work for you?
