Thanks ghostkeeper for the reply.
Sorry if my description isn't that great, I am new to this and still trying to get to grips with a lot of terms.
I did delete the Roaming\Cura folder. The models look to me to be suffering from under-extrusion, but I have the flow set at 100%. I was hoping that someone could confirm that it is an under-extrusion problem. I am assuming that it is a setting problem because I can print previous models fine, and the OK test model is also find. Also as I changed the hot-end back, I am feeling more convinced that it is a setting in Cura that is causing my problems. I just can't think which it would be. I have read a lot of forums and tried various scenarios but no change.
I think I will try another complete uninstall and re-install of Cura to see if that will help.
Thanks
Mark
ghostkeeper 105
Keep in mind that we moved the data in the AppData folder from %APPDATA%\Local\cura to %APPDATA%\Roaming\cura, so if you deleted stuff you'd have to delete the new location (or both).
It might be worth your while to see which of the settings are wrong (if the settings are wrong). That could pinpoint the actual problem better than your current description. We can't really debug this issue for you since we don't have access to the Wanhao.
