Maybe a parameter to define the amount of variation of temperature in wich should make a pause.
It's very frustrating that the change of one degree celsius could pause an entire print, everytime the extruder change.
I already tried Prime Tower, and the nozzle that will start to extrude will always stop on top of the print.
ultiarjan 1,215
If you skip the waiting like this I guess you risk underextrusion and very weak prints. Maybe using a primetower helps to avoid waiting time on top of the print? But better is to set a specific location in the toolchange gcode....
