Alternatively, to do an update, use the procedure described at https://ultimaker.com/en/resources/20500-upgrade-firmware to download the necessary files and put them on the USB drive.
Disconnect the network cable (which should prevent the looping for asking to upgrade the firmware), turn off the WiFi and make sure the USB stick is inserted.
Then you should be able to do a manual update of the firmware using the menu items System -> Maintenance -> Update firmware.
Daid 306
What is displayed exactly? As displaying the "firmware code" wouldn't show anything readable.
Most likely, you are hitting some kind of captive portal instead of our update servers. Meaning something else then our servers is answering to the update request.
If you are in an office environment, you should ask for some assistance of your network administrator, could be a firewall that is causing your problems.
(On our side, we should fix the code to not display whatever we get back from the server, but validate that it's a valid version number, as that is what it is trying to display. The response from http://software.ultimaker.com/jedi/releases/latest.version )
