Ok, thank you, I allready saw that the cracks were a common problem. But the rod that is on it, is not glued or anything? It worries me that that one came loose.
This way I can no longer print the side block caps :-(
Cheers,
Jan
Cheers,
Jan
Dear Jan,
The rods are only clamped in, but this is when the blocks are not broken enough to keep them firmly in place. However because of the crack it lost its grip and the rod can shoot out. I would advice to not print and repair it first to make sure you do not damage the machine.
Kind regards,
Job van Gennip
Labern 774
This is a well known issue. If you contact your reseller they will replace the block for you.
In the mean time if you still need to use your printer then you can print these to hold it together.
Job_van_gennip 23
The blocks are very fragile, this problem is known at ultimaker.
The best you can do is contact the store you bought it and send it to them for a repair (should be covered by warranty).
Kind regards,
Job van Gennip
