Tinker firmware G1 command printing out of printing area Simplify3d 1.75 SDCARD only
Octocom
Posted (edited) · Tinker firmware G1 command printing out of printing area Simplify3d 1.75 SDCARD only
Hey guys,
I'm trying to understand why a combination of Ultimaker 2  extended and Simplify3d causes out of print area with my custom area settings only on SDCARD, if you could give any pointers it would be appreciated.  I have also noted this only happens in simplify3d, cura etc are fine.
I have found if I use any G1 command for XY axis in the start script it will cause the error only on SDCARD, removed it works fine in Simplify3d or print from usb
I do have a custom print area setup due to metal sliders and e3d mount:
Ultimaker 2 extended custom 1.75 e3d mount and metal sliders
Firmware: Tinker 17.02.01, others tested
Print Area: x 0.00-205.00 Y 10.5 - 218.00 Z305.00
Software: Simplify3d 3.1.1
Testing start script: " G1 X xx and Y xx  commands fail"
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0
G28 Z0
G1 X15 ; tested x15 50 60
G1 Z50.0 F500
G92 E0 ; zero the extruded length
G1 F150 E25              ;extrude 9mm of feed stock
G92 E0                  ;zero the extruded length agai
M201 Z250
Luke
    Posted · Tinker firmware G1 command printing out of printing area Simplify3d 1.75 SDCARD only
    Correction for above Cura flavor RepRap and simplify3d RepRap code fails for same setup of stl's. only UltiGCode works on SDCARD. usb printing via simplify3d works fine or if I remove g1 commands from start script
    The position error is not checked during USB printing - this explains why it only happens if you start the print from sdcard.
    I tested your settings for the print area and the gcode lines, that you've posted above, but the error was not triggered... there must be something else in addition that causes this issue for you...?
