Problem during printing (Ultimaker Original)
Max83
Posted · Problem during printing (Ultimaker Original)
Hello,
With my Ultimaker Original, I can't print objects correctly.
At the beginning of the printing, everything works correctly, the object begins to be visualized. But
It's only after nearly a minute that the impression shifts and no longer follows the right trajectory.
I've fixed the feeder, I don't see where the problem comes from.
Here is attached a picture of an impression.
Hoping for an answer
    Thank you ! Indeed, the fan on the bottom of the printer wasn't working.
    If I change it, will the problem persist ? Or now, need i to change the motors ?
    do you know why the fan doesn't work? Did it work before as it should be?
    In my situation in both cases (2 different printers) there was a loose fan wire underneath and after readjusting everything worked again. Why or what would you change about the motors?
    I guess that the motors are loosing steps if they get too hot...
