stringing is often cured by lowering the print head temperature, strange that it starts only towards the top (cant see the inside of the front part, but I assume its there too)
maybe you could try dropping the temp by say 5 degrees - you could use the 'Tweak at Z plugin' so you don't have to sit and wait to make the change
Many thanks for your response. I tried reducing temperature, but no luck ! However, I'll try to use the 'Tweak at Z plugin'.
stu_le_brew 42
