Vertical turbine print issues at certain height.
vmuddu
Posted · Vertical turbine print issues at certain height.
Hi everyone,
I am trying to print vertical axis wind turbine, but my print fails at a certain height. I've used the recommended print settings for the TOP WING. Can anyone help me how to overcome this issue? Many thanks in advance.
Thank you
Vik
1.thumb.jpg.5c7e51b2e4898ecc6258f451b500123f.jpg[/media]
    stringing is often cured by lowering the print head temperature, strange that it starts only towards the top (cant see the inside of the front part, but I assume its there too)
    maybe you could try dropping the temp by say 5 degrees - you could use the 'Tweak at Z plugin' so you don't have to sit and wait to make the change
    Many thanks for your response. I tried reducing temperature, but no luck ! However, I'll try to use the 'Tweak at Z plugin'.
