0.9º XY motor replacement for greater accuracy?
Posted (edited) · 0.9º XY motor replacement for greater accuracy?
Has anyone tried replacing their XY motors with a 0.9º stepper motor? I found one that should fit (or require very little modification) but wanted to know if anyone has already tried this? My goal is to increase the accuracy to be able to hold +/-.001" (0.025mm) tolerances on parts. I usually print at slow speeds (20-40mm/s) so I'm not worried about the loss of speed.
    Posted · 0.9º XY motor replacement for greater accuracy?
    With this sort of accuracy there are so many things that have an effect and other things I would look at getting right first.
    PID bed control
    Constant room temp with no breeze's from aircon.
    Direct drive, Bowden is no good.
    I would even change the main board to something like the duet3d as it has newer drivers that can go to 256 micro stepping.
    Also need to make sure your bearings are good quality and don't have bent rods.
    Depending on your printers age, there is a newer belt and pulley profile which gives smoother motion.
    True, there are other factors that would need to be addressed (some of those items I have already taken care of) but the 0.9º stepper would provide better mechanical resolution without any major changes. I am simply curious if anyone has tried it and experienced any positive results.
