What kind of printer is this?
This is the part that primes. You could increase from 3mm to 6mm.
G1 F200 E3
A few lines above this it goes to position Z15. Does that at least work? Does it move such that the nozzle is 15mm above the printer right after homing?
The biggest difference I see is the "T0". That selects extruder 0 or "tool zero". Maybe your printer needs that or it won't extrude. I would put that before any temperature settings and especially add it to the lines that set the temperature: M104 and M109.
I'm guessing your brand of printer will not heat up the nozzle without that T0 in there and the extruder won't extrude if the nozzle is still cold.
Sorry for late reply, didn't get the notification.
Printer's main board is from Anet A8 (it's modded Anet A8 ).
The head heats up, I can see it on the screen and measured temperature of the heating element.
As I previously said, I managed to get 1 succesful print after slicing in Cura. I printed few first layers of this model again and it turns out it had the same issues on first layer, but because it had big solid bottom layer, filament 'cached' the bead. This first layer was a bit deformed, but other layers looked good.
Adding T0 don't change anything.
It looks like only first layer have under-extrusion issues. I didn't find an option to increase flow rate on first layer only, so I increased overal flow and it's a bit better, but the filament is still being dragged around.
# ^ I wrote that yesterday, but decided to hold on a bit more and tweak settings and the machine a few times
I decided to fully take apart my extruder, reassembled it, cleaned glass, re-leveled printer and started printing Benchy a bit slower and few settings tweaked and ... I never got first layer so clean. All the layers seem to be better than ever, I hope the print will finish well.
Thanks for your help.
gr5 2,196
G1 F200 E3
