hiya.,
I am not worried about the small size. been doing that on the UM2+ and the Wanhao.
how do you create them because I can't find where I can do that.
Rebekah
hiya.,
Rebekah
Where it displays the layer height you can select the dropdown menu and select save current settings as new profile (or something simular)
Labern 774
Yes you can create a new profile for the cores you are getting but you will have to adjust all the settings yourself save the profiles with the included settings.
The smaller cores are not as easy to print with so you will have to run quite a few tests to get good results and once you have found some good settings for the material your using then you can save that profile.
