Ultimaker 3 print cores
rebekah_harper
Posted · Ultimaker 3 print cores
Hiya all,
I was wondering if there is a way to create new print core profiles in Cura.
I have a 0.25 and a 0.15 coming and would prefer to create a core profile rather than doing the jiggery pokery in the settings.
many thanks
Rebekah
    Yes you can create a new profile for the cores you are getting but you will have to adjust all the settings yourself save the profiles with the included settings.
    The smaller cores are not as easy to print with so you will have to run quite a few tests to get good results and once you have found some good settings for the material your using then you can save that profile.
