The only reason I can tell that it shorts out is that the power light on the power brick goes off when I turn the unit on. I measured and after the unit is turned on I get no power coming from the brick.
Contact Ultimaker support (by email or phone) it's quite possible your electronics board was damaged during transport. They can set you up for a replacement.
gr5 2,224
How do you know the power is shorted? What was the clue? Did you measure the current?
It's likely you have a bad board :( but maybe you have a bad power brick?
