Is there a file limit on the UM2+ display for the SD card?
Posted
· Is there a file limit on the UM2+ display for the SD card?
If there is a file display limit
AFAIK - the short answer is: no. There's no limitation of the count of files.
Only the "directory depth" (don't know the correct phrase) is limited. One can navigate max. 10 directories "deep" (recursively) - that seems not to be the problem in your case.
tinkergnome 927
Have you tried to clean the sdcard slot?
