Launch Cura 2.6 and go to Help -> Show Configuration folder. Now close Cura.
These are the configuration files for Cura 2.6. They are in a folder named 2.6. On OSX, the configuration files for Cura 2.5 are one folder up (not in a folder named 2.5). You can copy files from that parent folder into the folder named 2.6, and Cura should update them as needed the next time it is started.
1
Siebet 27
Normally Cura wil overwrite your current Cura files and wil keep your settings, profiles and printers. If you want to keep the 2 versions, you can copy the files in Programs > Cura > Contests > Resources > resources > map of the files you want to copy...
