hi
i had the same problem with my umo.
my workaround was to switch the umo on, get the mintemp error, select preheat the nozzle, wait until the nozzle was above 60 degrees or so, switch the umo off and on again , and the min temp error was gone.
after a while i tried to solve it and read somewhere in the forum it can be due to a bad cable from the driver board to the electronics. as i had a dual head once installed i had another connector available and reinstalled that one and the min temp error was gone. so maybe check the connections to the thermistor or replace them could be a solution.
i recently upgraded to a pt100 without a problem so maybe also an idea as you have the um2 head already.
amedee 348
Strange...
The only time I got a MINTEMP was because I had the wrong polarity on the thermocouple, so an increase in temp would make the display go down. But you already tested that...
MINTEMP is triggered when the temp reading is below 5°C, so unless it is freezing in your workshop, I see no reason to get that error.
Maybe for whatever reason it takes some time for the probe to give an accurate temperature reading and this triggers the MINTEMP at power-on.
Are you still using the original thermocouple amplifier?
