Posted (edited) · Layer Question
In layer view if my layer one is a red "shell" but then green "Inner Wall" why isn't there any yellow for "top/bottom"?
Cura 2.5.0
.2 layer height
The pieces are smallish pieces for a model. Funnels for a boat.
All the way up the cylinder there is only green for inner wall and no orange for infill?
Does it matter that there is no bottom?
    Posted · Layer Question
    @Labern, sorry should have left photos.  Here they are.
    Solid view
    view?usp=sharing
    Layer 1
    view?usp=sharing
    Middle Layer
    view?usp=sharing
    Top layer
    view?usp=sharing
    Your images seem to invalid. Try loading them into you gallery first so you can preview them and make sure they loaded properly.
    @kmanstudios, There are so many, any in particular?
    Quality
    Shell
    Infill
    Material
    Speed
    Travel
    Cooling
    Solid view
    view?usp=sharing
    Layer 1
    view?usp=sharing
    Middle Layer
    view?usp=sharing
    Top layer
    view?usp=sharing
    I have them in a gallery now:
    Solid view
    Layer 1, bottom layer
    Layer 82, middle
    5a333ea78c5d9_funnellayer164top.thumb.jpg.8a3e79bae9ab41bcc5cb8078513278c6.jpgTop Layer
    Quality
    Shell
    Infill
    Material
    Speed
    Travel
    Cooling
    I would suggest taking a screenshot of the settings panel. That would be easiest. And it may show whether you need to 'unhide' some of the other controls that could be at play.
    Quality
    Shell
    Infill
    Material
    Speed
    Travel
    Cooling
    This is Cura 2.5.0 so it has all the "settings" in a bar on the right hand side with headings that open up to display the detail for each setting.
    I am on my way out without time to evaluate, but will check when I get out. In the meanwhile, it should help the real gurus here. I am just a noob with a bit more experience than you at this time. Not much more, mind you, but just trying to help. :)
    It looks like your wall thickness is so wide that there is no infill. Reduce your wall thickness to 3 lines
