Infill not printing correctly
ryandavidson
Posted · Infill not printing correctly
Personnaly i find that the default profiles have to high infill speeds, you can change them and lower them to the main printing speeds (if the infill speed is not visible click on the gear next to printing speeds to make it appear).
    Sounds good, ill give it a go!
    Cheers
        • 27 replies
