Print results Spiralize Outer Contour compared to "normal"
Posted
· Print results Spiralize Outer Contour compared to "normal"
What was your shell setting in spiralize? If it was 0.8mm shell and .4mm in spiralize mode then what is happening is it is makeing two .4mm passes in normal mode but in spiralize mode it makes a single .8mm pass (effectively doing 200% flow except... a few other details are different as well like position the head moves over).
so one way to get this watertight is to set the shell to 0.8 and nozzle to 0.8 (even though you have a 0.4mm nozzle). However if you do this I recommend you slow it down a lot to avoid underextrusion. I'd try 20mm/sec. So I would try those 2 changes - nozzle to 0.8 and speed to 20mm/sec. If you get any underextrusion maybe raise the temp by 10C but try it without raising temp first. In fact as it prints you can look at the quality and play with speed and temp a little.
gr5 2,210
