I have it set to be 30 seconds minimum per layer. I've tried up to 1 minute, with the same results.
I also tried printing the knife model tilted ~45 degrees with supports running along the backside of the knife and that one was far worse than the one I just printed vertical. Around the same height mark it turned wavy, almost like forced layer shift, however it "returned" to normal layer position after a bit.
Labern 772
As the model is getting smaller the higher it gets it might be effected by the minimum layer time then over heating. What is this time currently set at?
