Posted · g code problem?
hello,
raft and first layer with infill are good
the following layer there isnot comming anny fillament out of the extruder
design drawn in 123d , converted to stl and g code in cura(tried all versions)
were to look fore the mistake?
all help is welkom!
wr Henk
    thanks for the reply
    tried all versions of cura , best results with 16.0.1 came with the duplicator i3
    firts results were okay after experimenting with cura the problem of stopping extruder after first layer occ
    see pictures
    wr Henk
    5a333ed646083_20170827_17453088.thumb.jpg.e4a221404a021806471ffecc109675fe.jpg5a333ed535ce4_20170827_17444589.thumb.jpg.47c2c8ea97de7313e73c5e7005c28f2e.jpg[/media]
    how to upload an STL file?
    I'm not sure you can, but you could post a link to it.
    Thanks for the STL file. It slices OK for me and looks fine in the viewer. I haven't tried printing it.
    Does it look in the cura layer view for you?
    What happens when you print? When it has printed the first layer does the nozzle continue to move? Does the extruder try to extrude?
    In a viewer it looks okay
    Print starts okay layer 5 and following the extruder stops
    The movement cont
    After a few layers its clear that the extruder is not starting anymore
    Tried in more cura verions
    The movement cont
    The fillament is grinded and clogged fore the pfte
    Well, maybe you're trying to push too much plastic through the extruder and the filament is stripping - try reducing print speed or the width of the lines or upping the extruder temperature.
    tried all that,but no result
    can't reed the G code but i think its what you say ,pussing too much fillament
    from layer 5 and further but there is no fillament comming out
    will experiment futher
    thanks fore the support
    wr Henk
    Posted (edited) · g code problem?
    wr Henk
    After 1 1/2 week of problems finally printing with a good result!!
    Was drawing the reeds in 123design all from start and saw the options 1)to show the part 2)part with constr lines 3)constr lines only
    Never paid notions to that but i tried the option 1(part only)
    After that saved the stl and conv
    to g code in cura
    The g gode in a simulation showed a good print and the real print was now also with a good result without allthe problems of the last week
    So i think the constr lines were the problem in conversion with cura
    Wr Henk
