Spiralize and bottom prints
Koenvanos2
Posted · Spiralize and bottom prints
I was very happy with the function ' Spiralize printing' with ' Bottom print' in the old versions of Cure.
Currently I'm using Cura 2.7 and I cannot get this combination again.
Is there any option or trick which I overlooked so far?
Really appreciate your tips.
Thanks,
Koen
    Hi, I did not use the older version of Cura so I don't know what you mean by bottom print but I was involved in the development of the current spiralize mode. Can you please describe the end result you are trying to achieve? I may be able to suggest what to do.
    I would like to see 'walls' and 'bottoms' only. 'walls' made in a Spiralized way and 'bottoms' only at the printing table level.
    I played with 0% infill and bottom only, but than I still have 'bottoms' printed at higher Z-levels, which I would like to avoid.
    Thanks!
    Hi, isn't it just a matter of setting top thickness (top layers) to 0 and bottom thickness (bottom layers) to some value? If that doesn't work for you can you please post a link to the model or a screenshot?
    Thanks for your suggestion. That works well for top layers.
    I would like to see bottom layers only at Z=0 level (printed on the printable). At higher Z levels I do not want to see bottom layers printed on horizontal areas. However Cura prints them as bottom layers too. And with zero infill below this will result in problems.
    Sorry, I don't understand what you mean, could you please provide an image of the layer view that shows these bottom layers you are referring to?
    Obviously, when you spiralize, the model cannot have any areas whose slope is less than approx 45 deg because otherwise the layer above would not have a layer below to rest on and you would get holes appearing. But apart from the layers that start at the build plate you should not get any other skin layers.
        • 26 replies
