I used the "Keep Disconnected Faces" Cura option and it sliced better:
Just noticed that the skirt doesn't go around the car, it goes under it!
EDIT - just noticed that's OK because the car body rises above the build plate.
Edited by burtoogleI used the "Keep Disconnected Faces" Cura option and it sliced better:
I 've tried it but the Gap is still there. if you rotate the Model you will see it too.
I tried it second time and now it looks better :-)
Good, but remember, the model is badly broken. You need to fix it to be able to reliably print from it.
burtoogle 508
The model's broken, here's what FreeCAD thinks of it:
