My printer can print 210 x 210 x 205 mm and that's what I've put into netfabb setup. Nonetheless, nf displays a grid with 22 x 22 squares. In the netfabb graphic, the top row (the one across the back of the printer by the lead screw) and farthest right column of squares are "out of bounds." I just place the part manually and don't use that real estate.
I don't know how far off your parts are placed by nf, but the center of the actual build area many not be where you think it is!
Daid 303
The latest known stable firmware comes with the latest Cura. I highly recommend installing the firmware from there even if you use netfabb.
