Jury rig it while you get your printer up and running and then print replacementsSorry, but it had to be done
The irony of the situation is not lost on me :lol:
I'd just rather not run the risk of ruining the electronics if I can
The electronics need the cooling, and for proper cooling you better fit them properly. Instead of 2 bolts screwed into the threaded spacer you could take normal spacers and a long bolt with a single nut at the end. It will be more tricky to assemble, but still work.
IRobertI 521
Sorry, but it had to be done ![:p](//content.invisioncic.com/ultimake/emoticons/5a33abe3e5fc3_1f61bcopy.png)
