drifting print
Pantera09
Posted · drifting print
greetings all,
I have recently reconstructed an Ultimaker Original and was printing fine. The other day, during a print the layers started to drift. At first the drifting was +y and of late, was -y. But in each case the layer were accurate but drifting. Any thoughts?
I consider myself to be a novice and this is my first printer. Also, the cura software does not communicate with the printer effectively and will not level or run a printer check, and as a result I only print with the SD card.
thank you in advance,
09
    Hi and welcome,
    Not sure what you mean by drifting but check out this link and maybe the other thing just below (shifting layers) i think it might help
    thank you for responding, the site you directed to me is perfect and exactly what I need. I am positive that I can find answers to my issue here thank you very much.
    Pantera09
