It could be that the model is not watertight. Check an online model fixer.
Thank you for your hints.
I played around with the seven mesh fixes in the settings but I didn't notice any changes at all. At least not to the main problem of the model.
Additionally I uploaded my model to https://tools3d.azurewebsites.net/ and https://service.netfabb.com/ and let them repair the model. But the "fixed" model also had the same problem.
Is there another way to export my model from blender to cura than exporting it in x3d or stl? Is there a better way?
Try to export in obj. Set the top surface skin layers at least to two. In Cura 3 export the gcode or stl. I solved a similar problem this way.
kmanstudios 1,117
Do you mind letting one of us look at it? I love to solve modeling issues. I can take standard STL or OBJ files as that is what you would be using for the most part anyway.
But, I'd love to take a crack at it.
@earbud: Thanks, I exported is as obj in blender, and I am not quite sure what you meant with "Set the top surface skin layers at least to two". I didn't saw any export settings in blender. I tried to make my inner layer a bit thicker if that is what you meant, but that didn't help.
You can find the stl file here: Object.stl
Or a blender file here: Object.blend
Thanks for looking at them.
kmanstudios 1,117
The " top surface skin layers at least to two" is a Cura setting in the slicer. You will probably have to unhide a lot of settings to get to it. It should be in the "Shell" section if I remember correctly.
I'll download and take a quick look because well, I gotsta hop on a job But will definitely look.
kmanstudios 1,117
Dammit!!! Frikkin' site ate the reply GGRRrrrrrrrr.......And, no, back button did not work.
OK. Here is the short version:
1. Not in scale. Had to scale it up almost 900% to sorta match the size based on your object to virtual grid. That is not good.
2. Object not manifold. It was a collection of 2D parts with no thickness to each surface.
3. No matter what settings it was set at, Cura would either not slice it or would cap it to create depth and what you got was a solid with nothing but infill.
4. Taking the object and applying a thickness to your walls establishes your actual thickness and defines 'inside' and 'outside'. These are each part with thickness and made manifold.
This lets Cura slice and not have to worry about what it is trying to fix. Learning to model is important and this is lesson one.
Here is the fixed file at the size you made it. I have no idea what size it really should be and based my slicing off your image above.
1
kmanstudios 1,117
OK, this site just ate my reply twice. This is getting really bad. fortunately I had copied the shortened version of my reply this time. But, twice in a row is setting a new record.
@kmanstudios Thank you very much.
I saved the model you created for reference and backup, but I will try to remodel my own file with the errors you outlined in mind. They make sense to me, but I have not been aware of these points.
Thank you again for all the effort and the tips.
kmanstudios 1,117
It is no problem and you are most welcome. It is how we learn. Well, I learn that way at least.
Just remember two major things at this juncture:
1. Try to model at the scale you want. Cura (Actually slicers in general) wants to work at millimeters and that is a good place to start at in your package of choice.
2. Always have a thickness.
Good luck!!
DidierKlein 729
Hi and welcome,
Not really sure what is going on, probably something strange is happening awhen you export your model.
In cura, there are several options that you can play with, you can find them under mesh fixes (if i remember well), try selecting and unselecting, and combining them to see if it show the result you are aiming for
