Posted · Just discovered Wanhao filament spools do not play well with my UM2+
Ultimaker-compatible spool hubs have a smooth 52mm diameter hole - Wanhao holes are also 52mm overall but are full of struts and definitely do not fit on the UM2+ spool holder.
Before I start destroying Wanhao spools, any alternative suggestions gratefully appreciated.
I don't have an empty UM2+ spool handy which would be the simplest way.
Thanks!
    Posted (edited) · Just discovered Wanhao filament spools do not play well with my UM2+
    Thanks UbuntuBirdy,
    Nice smooth spoolholder. I've added it to my model library.
    For now I've printed the simpler one from thingiverse.
