If you are running windows. viewtopic.php?f=8&t=153 this version has all the default settings correct.
Tried the pypy and the result looks really good. I will need some calibration for my modified extruder but that's no big deal.
It's fast and the results I think the results will be quite good.
Thanks for the support
ddurant 0
You need to activate Dimension.
Make sure to measure your filament diameter accurately and put it in there, too.
