yet again another 'cannot connect error' with the new software, surely something is amiss?
Paul
Paul
Error Log
Changing monitoring state from 'Offline' to 'Opening serial port'
Connecting to: COM8
Connected to: Serial<id=0x350c670, open=True>(port='COM8', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=0.1, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from 'Opening serial port' to 'Detecting baudrate'
Trying baudrate: 250000
Send: M105
Baudrate test retry: 4
Send: M105
Baudrate test retry: 3
Send: M105
Baudrate test retry: 2
Send: M105
Baudrate test retry: 1
Send: M105
Baudrate test retry: 0
Send: M105
Trying baudrate: 230400
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Trying baudrate: 115200
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Trying baudrate: 57600
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Trying baudrate: 38400
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Trying baudrate: 19200
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Trying baudrate: 9600
Send: M105
Changing monitoring state from 'Detecting baudrate' to 'Closed'
Changing monitoring state from 'Closed' to 'Error: No more baudrates to...'
Connection closed, closing down monitor
I should mention that I had this same problem with a RAMPS 1.3 board and a different Arduino as well.
Odd. I've never tried sprinter myself (as we use Marlin), one of the things that could be it is that it takes a while for sprinter to be start-up. If you use pronterface, how long does it take to connect? (Pronterface uses very long timeouts, while those of Cura are pretty short)
Pronterface connects almost instantly. I have to swap out my heatbed thermistor for one that Marlin won't read as absolute zero so until then, I'm stuck with Sprinter. I've only realised there's a new version of Cura available so I'll upgrade and see if that helps.
Did the upgrade fix it? I know when I had trouble with my Gen 6 connecting, once I upgraded to 13.03 I believe it was Cura connected just as well as the others. Before I upgraded I was having the same issues you are.
I haven't had the chance to try it with the upgrade, I'll post results at the weekend when I give it a try.
Daid 304
Could you post the error log?
