Posted · Manual Leveling Error
In an attempt to level my printer more accurately, I was going through the manual leveling process. However, I have a 1+ cm gap between the extruder and the nozzle. I cannot even come close to getting the initial 1 mm gap before using the calibration card. Is there a way to manually raise the build plate prior to honing the calibration via the three screws below the build plate?
