Rotate_Extrude Problem
Posted · Rotate_Extrude Problem
I am trying to follow the Extruding a Polygon example in the OpenSCAD User Manual. I am getting a Preview result as shown in the attached photo. The Preview seems to have inherited the nominal 1 unit thickness of the polygon shape. When I progress to the Render function I get the following warnings:
Rendering Polygon Mesh using CGAL...
WARNING: Mixing 2D and 3D objects is not supported.
WARNING: Ignoring 3D child object for 2D operation
At the conclusion of the Render process the graphic displays just a 1 Dimensional red line on the x-axis.
Any idea what I am doing wrong here?
