Interface lag when changing setting
lukasz_b_g
Posted · Interface lag when changing setting
I was wondering if anyone also experiences immense interface lag after changing a setting? I first noticed it in about Cura 2.7, and it's happening on all of the computers I have it installed on. (Windows 10, not exactly slow) What could be causing this? I have the latest version of Cura installed, I use a lot of custom settings.
    Well, a lot of custom settings can mean that it requires a ton of re-calculation if you change a setting. Depending what setting it is, it can have a bigger impact. We've made some progress in improving this in 3.0 though.
