It tires to make that .4mm fill in diagonal lines which is tricky since there isn't much room for diagonal lines (in theory zero room).
Anyway it sounds like you need to redesign your heated bed. Or maybe you just need to change your print speed a bit so it doesn't vibrate at exactly the frequency that is messing up your "radial bearings".
gr5 2,224
