kmanstudios 1,074
Yes, I got the PVA to work with the PC. But keep in mind that it may just be the type of geometry in use. And, a couple of times, it would just peel up if there was a rush of cold into the area.You were able to get PVA supports to work well with PC? I was wondering if more were possible than the materials chart implies. I just got some Polymaker Poly-Max to try out. I kind of question the CPE vs. CPE+ as well considering PVA support from E3D states it works with Colorfabb nGen which is also a PET based co-polymer like CPE/CPE+
For instance, I had a print on today that was doing fine when I left. It has been getting colder here in Brooklyn but dry as well. So, I have been cracking the door to let in fresh air. I live in a basement apartment (Which I do love btw) so, cracking windows is not an option.
When I returned home from an appointment, it had warmed in the apartment. As soon as I came in opened the door and cracked it slightly, the sudden heat differential made a long piece warp enough that I had to abort the print. I know this to be as I had seen how well it was printing before the cooler air reached the print.
I also had to go to a PC Brim on One object because it just would not stay on the plate in one place. I think I found the issue (I made the part too thin and the PVA on top of it would pull as it cooled...so, user error) but am still printing with PC Brim.
I am hoping to post further about this with pics once the project is done since I did a few nifty things like the PVA supports, but also because I did a print, pause, fill with weights, and let print finish to enclose weights.
But, I do know it does not always work with the PVA.
Here are two pics of dolphins I printed in black PC that used PVA as a support:
cjryker06 0
