Simplify3D Profile for UM2 EXT+
Posted · Simplify3D Profile for UM2 EXT+
Hello everyone,
Like the title says I am looking for the Simplify3D Profile for UM2 EXT+
I have tried to do the standard profile load through the wizzard and it act likes it works then tells me it was not able to get the file from the server.
I also tried all of the other UM profiles and none of them seem to work? Maybe their servers are down? It worked last time I used it for my FFCP just fine.
If anyone has this stock profile I would much appreciate it so I can get this up and running :-) Super Excited about my new machine!
Have a good day!
    • 1 year later...
    Posted (edited) · Simplify3D Profile for UM2 EXT+
    Hey Tvb1996 did the profile work for the  UM2E+  ?
    I just came across this thread after playing unsuccessfully for the last year.
    Edited by domenick_s
    add detail
    This works like a charm with my UM2EXTENDED+ but I had to add starting and ending script (also explanation is here "
    Starting script (cura):
    G21 ;metric values
    G90 ;absolute positioning
    M82 ;set extruder to absolute mode
    M107 ;start with the fan off
    G28 Z0 ;move Z to bottom endstops
    G28 X0 Y0 ;move X/Y to endstops
    G1 X15 Y0 F4000 ;move X/Y to front of printer
    G1 Z15.0 F9000 ;move the platform to 15mm
    G1 F200 E10 ;extrude 10 mm of feed stock
    G1 Y50 F9000
    ;Put printing message on LCD screen
    M117 Printing...
    Ending script:
    M104 S0 ;extruder heater off
    M140 S0 ;heated bed heater off (if you have it)
    G91 ;relative positioning
    G1 E-1 F300  ;retract the filament a bit before lifting the nozzle, to release some of the pressure
    G1 Z+0.5 E-5 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more
    G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
    M84 ;steppers off
    ;Version _2.6 of the firmware can abort the print too early if the file ends
    ;too soon. However if the file hasn't ended yet because there are comments at
    ;the end of the file, it won't abort yet. Therefore we have to put at least 512
    ;bytes at the end of the g-code so that the file is not yet finished by the
    ;time that the motion planner gets flushed. With firmware version _3.3 this
    ;should be fixed, so this comment wouldn't be necessary any more. Now we have
    ;to pad this text to make precisely 512 bytes.
    Ultimaker 2 Extended+_2020.zip
    On 1.9.2020 at 21:07, Feidias_3D said:
    Dies funktioniert wie ein Zauber mit meinem UM2EXTENDED +, aber ich musste ein Start- und ein Endskript hinzufügen (auch eine Erklärung finden Sie hier "
    Startskript (Cura):
    G21; metrische Werte
    G90; absolute Positionierung
    M82; Extruder auf absoluten Modus
    M107 einstellen ; mit ausgeschaltetem Lüfter beginnen
    G28 Z0; Z zu den unteren Endanschlägen bewegen
    G28 X0 Y0; X / Y zu den Endanschlägen bewegen
    G1 X15 Y0 F4000; X / Y zu bewegen Vorderseite des Druckers
    G1 Z15.0 F9000; Plattform auf 15 mm
    G92 E0 stellen, extrudierte Länge
    G1 F200 E10 auf Null stellen, 10 mm Ausgangsmaterial
    G92 E0 extrudieren; extrudierte Länge erneut auf Null stellen
    G1 Y50 F9000
    ; Druckmeldung auf LCD-Bildschirm
    M117 setzen Drucken...
    Skript beenden:
    M104 S0; Extruderheizung aus
    M140 S0; Heizbettheizung aus (falls vorhanden)
    G91; relative Positionierung
    G1 E-1 F300; Filament vor dem Anheben der Düse etwas zurückziehen, um einen Teil des Drucks
    G1 Z + 0,5 E abzulassen -5 X-20 Y-20 - F9000; move Z bis ein wenig und Rückzugs - Filament noch mehr
    X0 Y0 G28; move X / Y zu Endanschläge min, so dass der Kopf aus dem Weg ist ,
    M84; Stepper off
    ; -Version _2.6 der Firmware kann den Druck zu früh abbrechen, wenn die Datei endet
    , zu früh. Wenn die Datei jedoch noch nicht beendet wurde, weil am
    Ende der Datei Kommentare vorhanden sind , wird sie noch nicht abgebrochen. Deshalb müssen wir mindestens 512 setzen
    Bytes am Ende des G-Codes, sodass die Datei zum
    Zeitpunkt des Löschens des Bewegungsplaners noch nicht fertig ist . Mit der Firmware-Version _3.3
    sollte dies behoben werden, damit dieser Kommentar nicht mehr benötigt wird. Jetzt müssen wir
    diesen Text auffüllen, um genau 512 Bytes zu erstellen.
    Hello my friend,
    is that only for PLA or also for ABS ?
    I am looking for good settings for ABS and my UM 2+ EX.
    Thanks in advance for the help!
    Stay healthy!
    Edited by Pat2018
    I am only printing with PLA despite proclaimed high quality and possibilities of the ABS. May be later or in the future I will try to use ABS.
    But in the slicer you can set the materiál similarly like in the PRUSA SLICER whot you can see in the uploaded file bellow.
    I am proud that I am from the same country like Mr. Prusa is. So I would like to recomend  or try another slicer - PRUSA SLICER.
    prusa_slicer.pdf
