cura 3.1 keeps resetting values
phantom
Posted · cura 3.1 keeps resetting values
Hi all,
Does anyone know why the values in this cura version keep resetting ??
I do not have this problem in 3.0.4
For example i enter 100% infill and when i enter the next field it changes back to the 20% as it was orginally set to. In layer view i even see it change to full infill and a second later it changes by itself back.
Wall thickness is at 0.8mm changing it too 1.2 mm just makes it go back when clicking or using tab to go to the next setting.
almost all values are like this.. :-(
non of this happens in 3.0.4 with exactly the same settings.
Anyone else experiencing this?
This is because of a bug in the beta you used, which left your configuration in a conflicting state.
Please remove the configuration folder for Cura 3.1. When you restart Cura 3.1, it will reimport your configuration from Cura 3.0.
  • Like 2
can you please advise where this config folder is?
Hey
4 minutes ago, phantom said:
Hi Chris,
It's in
c:\users\your name\AppData\Roaming\cura
AppData folder is a hidden folder so you might want to change your properties if it does not show up.
I looked and see no folder named configuration i
    In Cura, go to Help->Show Configuration folder. Then go up one folder and delete the folder named 3.1.
    Alternatively, press Winkey+R and type %APPDATA%\cura followed by enter, and delete the folder named 3.1
    ok, i deleted the 3.1 as well as 3.04 2.7 and 2.6 folders. I use pet-g as the material, i change the petg profile  temps from 210 /70 to 240/90 and i slice a file. result. 210/90 when i print What is going on?
    attached is a screenshot of my settings and the gcode generated.
    ;FLAVOR:Marlin
    ;TIME:36750
    ;Filament used: 36.9236m
    ;Layer height: 0.2
    ;Generated with Cura_SteamEngine 3.1.0
    M82 ; absolute extrusion mode
    G21 ; set units to millimeters
    G90 ; use absolute positioning
    M104 S210 ; set extruder temp
    M140 S90 ; set bed temp
    M190 S90 ; wait for bed temp
    M109 S210 ; wait for extruder temp
    PI3MK2_Brave Lappi-Esboo.gcode
    14 hours ago, ahoeben said:
    Deleting the 3.0 and 2.7 folders wasn’t necessary.
    The temperatures in the start gcode is a bug in Cura 3.1 that will be fixed in Cura 3.2
    I kind of beg to differ, there was probably 100 MB or more in each folder. That's pretty messy and a waste of space.
    Thanks for letting me know about the start temp, that was driving me crazy, and it was probably the issue all along for me.
    Can't wait for 3.2, using slic3r right now and it is so much cruder (in my opinion) than cura.
