Posted · pythonw.exe stopped working, Windows 7
I tried doing a 15 hour print (the extremely popular mesh bird feeder on Thingiverse) and my printer stopped with the "pythonw.exe stopped working" showing up on my laptop. Based on what I've read, I should check the log file, but I don't see any errors:
# Generating comtypes.gen._683BF642_E9CA_4124_BE43_67065B2FA653_0_1_0
# Generating comtypes.gen.TaskbarLib
Listening for engine communications on 49674
Running: C:\Program Files (x86)\Cura_15.04.2\CuraEngine.exe -v -p -s initialSpeedupLayers=4 -s minimalFeedrate=100 -s preSwitchExtruderCode=;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added before the T(n)
 -s supportXYDistance=700 -s insetXSpeed=45 -s retractionZHop=103 -s extruderOffset[3].X=0 -s extruderOffset[3].Y=0 -s postSwitchExtruderCode=;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added after the T(n)
 -s retractionSpeed=40 -s filamentFlow=100 -s infillOverlap=5 -s inset0Speed=45 -s coolHeadLift=0 -s extrusionWidth=400 -s upSkinCount=3 -s initialLayerSpeed=25 -s minimalLayerTime=10 -s infillSpeed=45 -s supportExtruder=-1 -s fanSpeedMax=100 -s supportType=1 -s enableCombing=1 -s fanSpeedMin=100 -s supportZDistance=150 -s supportEverywhere=0 -s filamentDiameter=1750 -s initialLayerThickness=300 -s supportAngle=-1 -s fanFullOnLayerNr=1 -s extruderOffset[1].X=0 -s extruderOffset[1].Y=21600 -s layerThickness=300 -s endCode=;End GCode
M104 S0                     ;extruder heater off
M140 S0                     ;heated bed heater off (if you have it)
G91                                    ;relative positioning
G1 E-1 F300                            ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F3300 ;move Z up a bit and retract filament even more
G28 X0 Y0                              ;move X/Y to min endstops, so the head is out of the way
M84                         ;steppers off
G90                         ;absolute positioning
;CURA_PROFILE_STRING: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
 -s minimalExtrusionBeforeRetraction=20 -s retractionMinimalDistance=1500 -s skirtMinLength=150000 -s objectSink=0 -s retractionAmount=3500 -s skinSpeed=45 -s skirtLineCount=4 -s startCode=M109 S208.000000
;Sliced at: Thu 26-10-2017 21:03:33
;Basic settings: Layer height: 0.3 Walls: 0.8 Fill: 15
;Print time: #P_TIME#
;Filament used: #F_AMNT#m #F_WGHT#g
;Filament cost: #F_COST#
;M190 S70 ;Uncomment to add your own bed temperature line
;M109 S208 ;Uncomment to add your own temperature line
G21        ;metric values
M82        ;set extruder to absolute mode
M107       ;start with the fan off
G28 Z0     ;move Z to min endstops
G29
G1 Z2.0 F3300 ;move the platform down 15mm
G92 E0                  ;zero the extruded length
G1 F200 E3              ;extrude 3mm of feed stock
G92 E0                  ;zero the extruded length again
G1 F3300
;Put printing message on LCD screen
M117 Printn stuff
 -s skirtDistance=2000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=45 -s fixHorrible=1 -s layer0extrusionWidth=400 -s moveSpeed=55 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=2666 -s insetCount=2 -s downSkinCount=3 -s multiVolumeOverlap=150 -g 49674 -s posx=125000 -s posy=125000 $
Cura_SteamEngine version 15.04.2
Copyright (C) 2014 David Braam
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU Affero General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
GNU Affero General Public License for more details.
You should have received a copy of the GNU Affero General Public License
along with this program.  If not, see <http://www.gnu.org/licenses/>.
Default config 'default.cfg' not used
Reading mesh from socket with 563922 vertexes
 -s retractionSpeed=40 -s filamentFlow=100 -s infillOverlap=5 -s inset0Speed=45 -s coolHeadLift=0 -s extrusionWidth=400 -s upSkinCount=8 -s initialLayerSpeed=25 -s minimalLayerTime=10 -s infillSpeed=45 -s supportExtruder=-1 -s fanSpeedMax=100 -s supportType=1 -s enableCombing=1 -s fanSpeedMin=100 -s supportZDistance=150 -s supportEverywhere=0 -s filamentDiameter=1750 -s initialLayerThickness=100 -s supportAngle=-1 -s fanFullOnLayerNr=4 -s extruderOffset[1].X=0 -s extruderOffset[1].Y=21600 -s layerThickness=100 -s endCode=;End GCode
M84                         ;steppers off
;CURA_PROFILE_STRING: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
;Sliced at: Thu 26-10-2017 21:03:35
;Basic settings: Layer height: 0.1 Walls: 0.8 Fill: 15
G21        ;metric values
G29
G1 F3300
M117 Printn stuff
 -s skirtDistance=2000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=45 -s fixHorrible=1 -s layer0extrusionWidth=400 -s moveSpeed=55 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=2666 -s insetCount=2 -s downSkinCount=8 -s multiVolumeOverlap=150 -g 49674 -s posx=125000 -s posy=125000 $
Loaded from disk in 1.513s
Analyzing and optimizing model...
Face counts: 187974 -> 168517 89.6%
Vertex counts: 563922 -> 84220 14.9%
Size: 25.892000 15.000000 33.799000
vMin: 112.054000 117.500000 0.000000
vMax: 137.946000 132.500000 33.799000
vMin: -12.946000 -7.500000 0.000000
vMax: 12.946000 7.500000 33.799000
Matrix: 1.000000 0.000000 0.000000
Matrix: 0.000000 1.000000 0.000000
Matrix: 0.000000 0.000000 1.000000
Optimize model 1.435s
Slicing model...
Layer count: 338
Sliced model in 1.560s
Generating support map...
Generating layer parts...
Generated layer parts in 0.359s
Generated inset in 2.980s
M84                         ;steppers off
;Sliced at: Thu 26-10-2017 21:03:46
G21        ;metric values
G29
G1 F3300
M117 Printn stuff
 -s skirtDistance=2000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=45 -s fixHorrible=1 -s layer0extrusionWidth=400 -s moveSpeed=55 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=2666 -s insetCount=2 -s downSkinCount=8 -s multiVolumeOverlap=150 -g 49674 -s posx=125000 -s posy=137000 $
Reading mesh from socket with 564018 vertexes
Loaded from disk in 1.529s
Closing down
Closing down
Closing down
Closing down
['changeZ', '2']
Closing down
Closing down
Exception in thread Thread-6 (most likely raised during interpreter shutdown):Listening for engine communications on 49674
Closing down
Closing down
['changeZ', '2']
['changeZ', '2']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '2']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '2']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '2']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '2']
['changeZ', '2']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '2']
['changeZ', '2']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
Closing down
Traceback (most recent call last):
  File "Cura\util\printerConnection\printerConnectionBase.py", line 151, in _doCallback
    callback(self, param)
  File "Cura\gui\printWindow.py", line 269, in _doPrinterConnectionUpdate
    wx.CallAfter(self.__doPrinterConnectionUpdate, connection, extraInfo)
  File "C:\Program Files (x86)\Cura_15.04.2\python\lib\site-packages\wx-2.8-msw-unicode\wx\_core.py", line 14610, in __getattr__
Running: C:\Program Files (x86)\Cura_15.04.2\CuraEngine.exe -v -p -s initialSpeedupLayers=4 -s minimalFeedrate=10 -s preSwitchExtruderCode=;Switch between the current extruder and the next extruder, when printing with multiple extruders.
 -s supportXYDistance=700 -s insetXSpeed=45 -s retractionZHop=0 -s extruderOffset[3].X=0 -s extruderOffset[3].Y=0 -s postSwitchExtruderCode=;Switch between the current extruder and the next extruder, when printing with multiple extruders.
 -s retractionSpeed=40 -s filamentFlow=100 -s infillOverlap=15 -s inset0Speed=45 -s coolHeadLift=0 -s extrusionWidth=400 -s upSkinCount=3 -s initialLayerSpeed=35 -s minimalLayerTime=5 -s infillSpeed=45 -s supportExtruder=-1 -s fanSpeedMax=100 -s supportType=1 -s enableCombing=0 -s fanSpeedMin=100 -s supportZDistance=150 -s supportEverywhere=0 -s filamentDiameter=1750 -s initialLayerThickness=300 -s supportAngle=-1 -s fanFullOnLayerNr=2 -s extruderOffset[1].X=0 -s extruderOffset[1].Y=21600 -s layerThickness=198 -s endCode=;End GCode
G1 Z+0.5 E-5 X-20 Y-20 F4200 ;move Z up a bit and retract filament even more
M84                         ;steppers off
;CURA_PROFILE_STRING:eNrtWktv20YQvhJCf8QeEzRWSUqK7Qi8JLV9SYoAdtHEF2JFrsRtSC6xu7QsG/rv/Xb5ECVTqdMabR7ywTI/zszOznzzAOSUrpgME8YXiQ7coXd6MnaWNE1DnfDoU86UAnriSKYljTQXechyOktZcCVL5iiR8jhMrY2uwtiZc9iIWa64XgXexMnF3V3KQsXvmH1fSJ7rUBWMxcF4Uj9qlhVMUl1KFvie+xD1gx5w1AeO+8BJC85YvHXaseuosiiE1MFvImdOkVI9FzILaZwwhWtXcC0TxiVNQ3arZWnfvRY6cZa8YKEWSyaDc5oq1gHCG5GWGTNxEOIOUUg4S+NaDJGiGYNPMcenhro3PJ48hM3dH4CjPnDcB0664DwVy8Bz3aHbzWydjR2UZqLMdeB1MXv/5sXL4aT7LuN5iIcblgbjLh6JbMbzRUWcbXmebYUTDvhdiUQUBnNmQmuRbRFt5FjyueGSxzoJ59AQ0tzMEbM/WQSG8fwTbi5umExpYR03NJ84lYv1nY9b4xWXK3Q0cXhuiVw9Gx8s46lktIPxXDHt7gK3HSASIrWBqUuFgwxIMW2qKa7L6RMHuVKeM0TLxNavoQUtgpE53T41EUtZvtAJWGWOMMbmJXxta/mlxSonTETapzCjtxZp3ZoDRSWAoTWYMIq65nNdk7QqdI1EdOq+ClmF2DDVUTY8R2VxyzuUGgqJhVUka/W6jPSqYMFbXFe1EM0XaC4v23IMreHKt0kL3q7Aa6VpHrFgeNzCdxvU5lgVXNLUtJz6Fjwr0IQyETfIDF5uBRzUp3OEmMoFz4PJsH62IqqgkWHwqEFnVLEdOm5wo2JZiXqu5dF5mARHt5X84923G1XTKu1LyiVIEKIzW0J1MGPBrwBV1vqGZSrYQfvObDW2TpzzWxSdlBzUDMvcdgEzEpCukDb53i8yaztbVwYhEQXLwxnXqk8A9W/GxQ3irLmOEhPpSqxISyQDGQKFFkFT2REz8QpvgyNvB1oB+gk8kHq4iEyuL/wT8sElH11y7Q4uTn1yhg//1GF5XEtMz/KYXLzBn4N3njsmly7p+5naJhUzSVAgOIqI+RwKY3evgpWLCeZNR4U843OyEiVJ0IMI18/hlEce8TOVDIMJMSKFwGRF1BGlwYVHzo48cj5y3b9Rti2V6ISRZhQQSpAQUhUpMRUPi1aimtgviBYEpzJQmiiRMfhvXxcSTMLoNKdf/+wOJ/BhQj4c+Yiz+XV+3+2wazLN0B3INSmL+kiKiDcetd6wG5aTTBizbc4+HxFr9sMvH42faGUEOVXoU+oFvLWOmlZGuCKi1I3vS7oavDsZ7zeqNCvQwZTN78Xpfh+mdIZeWOrthEzvCylwJ0NlrBuLtWPZ6Ddku0x5BEJQ/Yrcx3S1Nr81w4cZDOvB9DVVPCKYISYZ6hV5a+qZVI0dKmlnZ1uTP1B3kLnf3trW5ByNE3B3EYPp92b9IeYcvKsXpOrQ8yYHqNS4UqyWhWrOr7MOtKzOXnS0IqF0V8s8w+o7D9G7vO/dukCK33OsBVYf6aNxbKoCJbLMbcV0ZInpUMacKc77B5vdZ031mjklV16fJf8fmXL/vVMXvrchNeoCDLihaclUl4D9fIMPxxvqgmlkyXVS1TnNKxJvymlvyViha7dTV9cPRVDtHsbinvq2naHenUls7ulNsmxwtae7TS+XptWbU4ymj5bQdNi6T/fo3DFZideiMakWIePbuY8eeOa5vV2beG6WmR5g1h2C+0SfvvwUQheU55uzju779+L14Mp91KXnXCr9LV17O/FoKWislvtmcmToPXSBKZGTt29+JSqSjOUgqHdM3tcyw+HQTF5/z+i9cr9w+hod7zCxDxP76Sf26DCxDxP7x5zY/o84sQ9rymFN2VlTRv/nmmJ0/MNqc1htnn61GR9Wm69qtfGfbrU5bEn/2ZY0etTsHMPp72hheNxqOPq+Ln1YDQ+r4c5qOP7WVkOjMzqsk4d18mnXyfrb9+43ri24+Yq1+seCLSGLdCQkw4yN2DBSN4GDJFRt5qzmZbuwVs1nxvQSlWkvHZVS2hA3FDYJsIkG0qIvyDKBQlvpdpnIylTzIm3bhVTDwfQqQVDNaSa4WG8syy2LjNGrZ/lzBzHRX5N/dG4KsHHvL73F2VA=
 -s minimalExtrusionBeforeRetraction=20 -s retractionMinimalDistance=4000 -s skirtMinLength=150000 -s objectSink=0 -s retractionAmount=1000 -s skinSpeed=45 -s skirtLineCount=2 -s startCode=M190 S70.000000
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
 -s skirtDistance=3000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=45 -s fixHorrible=1 -s layer0extrusionWidth=400 -s moveSpeed=70 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=2666 -s insetCount=2 -s downSkinCount=3 -s multiVolumeOverlap=150 -g 49674 -s posx=125000 -s posy=137000 $
Face counts: 188006 -> 168549 89.7%
Vertex counts: 564018 -> 84238 14.9%
Size: 25.892000 39.000000 33.799000
vMax: 137.946000 156.500000 33.799000
vMax: 12.946000 31.500000 33.799000
Optimize model 1.513s
Slicing model...
Layer count: 170
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '3']
['changeZ', '8']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '3']
['changeZ', '8']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '3']
['changeZ', '3']
['changeZ', '3']
['changeZ', '3']
['changeZ', '3']
['changeZ', '4']
['changeZ', '4']
['changeZ', '4']
['changeZ', '4']
['changeZ', '4']
['changeZ', '5']
['changeZ', '5']
['changeZ', '5']
['changeZ', '5']
['changeZ', '5']
['changeZ', '6']
['changeZ', '6']
['changeZ', '6']
['changeZ', '6']
['changeZ', '6']
['changeZ', '7']
['changeZ', '7']
['changeZ', '7']
['changeZ', '7']
['changeZ', '7']
['changeZ', '8']
['changeZ', '8']
['changeZ', '8']
['changeZ', '8']
['changeZ', '8']
['changeZ', '9']
['changeZ', '9']
['changeZ', '9']
['changeZ', '9']
['changeZ', '9']
['changeZ', '10']
['changeZ', '10']
['changeZ', '10']
['changeZ', '10']
['changeZ', '10']
['changeZ', '11']
['changeZ', '11']
['changeZ', '11']
['changeZ', '11']
['changeZ', '11']
['changeZ', '12']
['changeZ', '12']
['changeZ', '12']
['changeZ', '12']
['changeZ', '12']
['changeZ', '13']
['changeZ', '13']
['changeZ', '13']
['changeZ', '13']
['changeZ', '13']
['changeZ', '14']
['changeZ', '14']
['changeZ', '14']
['changeZ', '14']
['changeZ', '14']
['changeZ', '15']
['changeZ', '15']
['changeZ', '15']
['changeZ', '15']
['changeZ', '15']
['changeZ', '16']
['changeZ', '16']
['changeZ', '16']
['changeZ', '16']
Failed to listen on port: 49674
Listening for engine communications on 49675
Closing down
['changeZ', '16']
['changeZ', '17']
['changeZ', '17']
['changeZ', '17']
['changeZ', '17']
['changeZ', '17']
['changeZ', '18']
['changeZ', '18']
['changeZ', '18']
['changeZ', '18']
['changeZ', '18']
['changeZ', '19']
['changeZ', '19']
['changeZ', '19']
['changeZ', '19']
['changeZ', '19']
['changeZ', '20']
['changeZ', '20']
['changeZ', '20']
['changeZ', '20']
['changeZ', '20']
['changeZ', '21']
['changeZ', '21']
['changeZ', '21']
['changeZ', '21']
['changeZ', '21']
['changeZ', '22']
['changeZ', '22']
['changeZ', '22']
['changeZ', '22']
['changeZ', '22']
['changeZ', '23']
['changeZ', '23']
['changeZ', '23']
['changeZ', '23']
['changeZ', '23']
['changeZ', '24']
['changeZ', '24']
['changeZ', '24']
['changeZ', '24']
['changeZ', '24']
['changeZ', '25']
['changeZ', '25']
['changeZ', '25']
['changeZ', '25']
['changeZ', '25']
['changeZ', '26']
['changeZ', '26']
['changeZ', '26']
['changeZ', '26']
['changeZ', '26']
['changeZ', '27']
['changeZ', '27']
['changeZ', '27']
['changeZ', '27']
['changeZ', '27']
['changeZ', '28']
['changeZ', '28']
['changeZ', '28']
['changeZ', '28']
['changeZ', '28']
['changeZ', '29']
['changeZ', '29']
['changeZ', '29']
['changeZ', '29']
['changeZ', '29']
['changeZ', '30']
['changeZ', '30']
['changeZ', '30']
['changeZ', '30']
['changeZ', '30']
['changeZ', '31']
['changeZ', '31']
['changeZ', '31']
['changeZ', '31']
['changeZ', '31']
['changeZ', '32']
['changeZ', '32']
['changeZ', '32']
['changeZ', '32']
['changeZ', '32']
['changeZ', '33']
['changeZ', '33']
['changeZ', '33']
['changeZ', '33']
['changeZ', '33']
['changeZ', '34']
['changeZ', '34']
['changeZ', '34']
['changeZ', '34']
['changeZ', '34']
['changeZ', '35']
['changeZ', '35']
['changeZ', '35']
['changeZ', '35']
['changeZ', '35']
['changeZ', '36']
['changeZ', '36']
['changeZ', '36']
['changeZ', '36']
['changeZ', '36']
['changeZ', '37']
['changeZ', '37']
['changeZ', '37']
['changeZ', '37']
['changeZ', '37']
['changeZ', '38']
['changeZ', '38']
['changeZ', '38']
['changeZ', '38']
['changeZ', '38']
['changeZ', '39']
['changeZ', '39']
['changeZ', '39']
['changeZ', '39']
['changeZ', '39']
['changeZ', '40']
['changeZ', '40']
['changeZ', '40']
['changeZ', '40']
['changeZ', '40']
['changeZ', '41']
['changeZ', '41']
['changeZ', '41']
['changeZ', '41']
['changeZ', '41']
['changeZ', '42']
['changeZ', '42']
['changeZ', '42']
['changeZ', '42']
['changeZ', '42']
['changeZ', '43']
['changeZ', '43']
['changeZ', '43']
['changeZ', '43']
['changeZ', '43']
['changeZ', '44']
['changeZ', '44']
['changeZ', '44']
['changeZ', '44']
['changeZ', '44']
['changeZ', '45']
['changeZ', '45']
['changeZ', '45']
['changeZ', '45']
['changeZ', '45']
['changeZ', '46']
['changeZ', '46']
['changeZ', '46']
['changeZ', '46']
['changeZ', '46']
['changeZ', '47']
['changeZ', '47']
['changeZ', '47']
['changeZ', '47']
['changeZ', '47']
['changeZ', '48']
['changeZ', '48']
['changeZ', '48']
['changeZ', '48']
['changeZ', '48']
['changeZ', '49']
['changeZ', '49']
['changeZ', '49']
['changeZ', '49']
['changeZ', '49']
['changeZ', '50']
['changeZ', '50']
['changeZ', '50']
['changeZ', '50']
['changeZ', '50']
['changeZ', '51']
['changeZ', '51']
['changeZ', '51']
['changeZ', '51']
['changeZ', '51']
['changeZ', '52']
['changeZ', '52']
['changeZ', '52']
['changeZ', '52']
['changeZ', '52']
['changeZ', '53']
['changeZ', '53']
['changeZ', '53']
['changeZ', '53']
['changeZ', '53']
['changeZ', '54']
['changeZ', '54']
['changeZ', '54']
['changeZ', '54']
['changeZ', '54']
['changeZ', '55']
['changeZ', '55']
['changeZ', '55']
['changeZ', '55']
['changeZ', '55']
['changeZ', '56']
['changeZ', '56']
['changeZ', '56']
['changeZ', '56']
['changeZ', '56']
['changeZ', '57']
['changeZ', '57']
['changeZ', '57']
['changeZ', '57']
['changeZ', '57']
['changeZ', '58']
['changeZ', '58']
['changeZ', '58']
['changeZ', '58']
['changeZ', '58']
['changeZ', '59']
['changeZ', '59']
['changeZ', '59']
['changeZ', '59']
['changeZ', '59']
['changeZ', '60']
['changeZ', '60']
['changeZ', '60']
['changeZ', '60']
['changeZ', '60']
['changeZ', '61']
['changeZ', '61']
['changeZ', '61']
['changeZ', '61']
['changeZ', '61']
['changeZ', '62']
['changeZ', '62']
['changeZ', '62']
['changeZ', '62']
['changeZ', '62']
['changeZ', '63']
['changeZ', '63']
['changeZ', '63']
['changeZ', '63']
['changeZ', '63']
['changeZ', '64']
['changeZ', '64']
['changeZ', '64']
['changeZ', '64']
['changeZ', '64']
['changeZ', '65']
['changeZ', '65']
['changeZ', '65']
['changeZ', '65']
['changeZ', '65']
['changeZ', '66']
['changeZ', '66']
['changeZ', '66']
['changeZ', '66']
['changeZ', '66']
['changeZ', '67']
['changeZ', '67']
['changeZ', '67']
['changeZ', '67']
['changeZ', '67']
['changeZ', '68']
['changeZ', '68']
['changeZ', '68']
['changeZ', '68']
['changeZ', '68']
['changeZ', '69']
['changeZ', '69']
['changeZ', '69']
['changeZ', '69']
['changeZ', '69']
['changeZ', '70']
['changeZ', '70']
['changeZ', '70']
['changeZ', '70']
['changeZ', '70']
['changeZ', '71']
['changeZ', '71']
['changeZ', '71']
['changeZ', '71']
['changeZ', '71']
['changeZ', '72']
['changeZ', '72']
['changeZ', '72']
['changeZ', '72']
['changeZ', '72']
['changeZ', '73']
['changeZ', '73']
 -s retractionSpeed=40 -s filamentFlow=100 -s infillOverlap=15 -s inset0Speed=45 -s coolHeadLift=0 -s extrusionWidth=400 -s upSkinCount=4 -s initialLayerSpeed=35 -s minimalLayerTime=5 -s infillSpeed=45 -s supportExtruder=-1 -s fanSpeedMax=100 -s supportType=1 -s enableCombing=0 -s fanSpeedMin=100 -s supportZDistance=150 -s supportEverywhere=0 -s filamentDiameter=1750 -s initialLayerThickness=300 -s supportAngle=-1 -s fanFullOnLayerNr=2 -s extruderOffset[1].X=0 -s extruderOffset[1].Y=21600 -s layerThickness=200 -s endCode=;End GCode
M84                         ;steppers off
;CURA_PROFILE_STRING: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
 -s minimalExtrusionBeforeRetraction=20 -s retractionMinimalDistance=4000 -s skirtMinLength=150000 -s objectSink=0 -s retractionAmount=1000 -s skinSpeed=45 -s skirtLineCount=4 -s startCode=M190 S70.000000
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
 -s skirtDistance=5000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=45 -s fixHorrible=1 -s layer0extrusionWidth=400 -s moveSpeed=70 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=2666 -s insetCount=2 -s downSkinCount=4 -s multiVolumeOverlap=150 -g 49674 -s posx=125000 -s posy=125000 $
 -s retractionSpeed=40 -s filamentFlow=100 -s infillOverlap=15 -s inset0Speed=45 -s coolHeadLift=0 -s extrusionWidth=400 -s upSkinCount=10000 -s initialLayerSpeed=35 -s minimalLayerTime=5 -s infillSpeed=45 -s supportExtruder=-1 -s fanSpeedMax=100 -s supportType=1 -s enableCombing=0 -s fanSpeedMin=100 -s supportZDistance=150 -s supportEverywhere=0 -s filamentDiameter=1750 -s initialLayerThickness=300 -s supportAngle=-1 -s fanFullOnLayerNr=2 -s extruderOffset[1].X=0 -s extruderOffset[1].Y=21600 -s layerThickness=200 -s endCode=;End GCode
M84                         ;steppers off
;CURA_PROFILE_STRING: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
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
 -s skirtDistance=5000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=45 -s fixHorrible=1 -s layer0extrusionWidth=400 -s moveSpeed=70 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=400 -s insetCount=2 -s downSkinCount=10000 -s multiVolumeOverlap=150 -g 49674 -s posx=125000 -s posy=125000 $
Reading mesh from socket with 5490186 vertexes
Loaded from disk in 14.414s
Face counts: 1830062 -> 1828362 99.9%
Vertex counts: 5490186 -> 905913 16.5%
Size: 138.264000 220.168000 143.249000
vMin: 55.868000 14.916000 0.000000
vMax: 194.132000 235.084000 143.249000
vMin: -69.132000 -110.084000 0.000000
vMax: 69.132000 110.084000 143.249000
Optimize model 17.909s
Slicing model...
Layer count: 716
Sliced model in 27.004s
Generated layer parts in 15.210s
Exception in thread Thread-69:
  File "C:\Program Files (x86)\Cura_15.04.2\python\lib\threading.py", line 552, in __bootstrap_inner
    self.run()
  File "C:\Program Files (x86)\Cura_15.04.2\python\lib\threading.py", line 505, in run
    self.__target(*self.__args, **self.__kwargs)
  File "Cura\util\sliceEngine.py", line 254, in _socketConnectionThread
    length = struct.unpack('@i', sock.recv(4))[0]
error: [Errno 10054] An existing connection was forcibly closed by the remote host
M84                         ;steppers off
;CURA_PROFILE_STRING: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
 -s minimalExtrusionBeforeRetraction=20 -s retractionMinimalDistance=4000 -s skirtMinLength=200000 -s objectSink=0 -s retractionAmount=1000 -s skinSpeed=45 -s skirtLineCount=5 -s startCode=M190 S70.000000
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
 -s skirtDistance=8000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=45 -s fixHorrible=1 -s layer0extrusionWidth=400 -s moveSpeed=70 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=400 -s insetCount=2 -s downSkinCount=10000 -s multiVolumeOverlap=150 -g 49674 -s posx=125000 -s posy=125000 $
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
Closing down
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '3']
['changeZ', '3']
['changeZ', '3']
['changeZ', '3']
['changeZ', '3']
['changeZ', '4']
['changeZ', '4']
['changeZ', '4']
['changeZ', '4']
['changeZ', '4']
['changeZ', '5']
['changeZ', '5']
['changeZ', '5']
['changeZ', '5']
['changeZ', '5']
['changeZ', '6']
['changeZ', '11']
M84                         ;steppers off
;CURA_PROFILE_STRING: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
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
 -s skirtDistance=10000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=45 -s fixHorrible=1 -s layer0extrusionWidth=400 -s moveSpeed=70 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=400 -s insetCount=2 -s downSkinCount=10000 -s multiVolumeOverlap=150 -g 49674 -s posx=125000 -s posy=125000 $
Loaded from disk in 14.399s
Optimize model 16.240s
Slicing model...
Layer count: 716
Sliced model in 24.882s
Generated layer parts in 13.089s
M84                         ;steppers off
;CURA_PROFILE_STRING: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
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
 -s skirtDistance=10000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=45 -s fixHorrible=1 -s layer0extrusionWidth=440 -s moveSpeed=70 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=400 -s insetCount=2 -s downSkinCount=10000 -s multiVolumeOverlap=150 -g 49674 -s posx=125000 -s posy=125000 $
Loaded from disk in 14.243s
Optimize model 16.412s
Slicing model...
Layer count: 716
G1 Z+0.5 E-5 X-20 Y-20 F6000 ;move Z up a bit and retract filament even more
M84                         ;steppers off
;CURA_PROFILE_STRING:eNrtWktv20YQvhJCf8QeEzRWSUqK4wi8JLV9SYoAdtHEF2JFrsStSS6xu7QsG/rv/Xb5ECVTqdMabR7ywTI/zszOznzzAOSUrpgME8YXiQ7coe8saZqGOuHRdc6UAvTKkUxLGmku8pDldJay4FKWzFEi5XGYWgPbCnMOGzHLFderwHNdJxd3dykLFb9jEBg7heS5DlXBWByMJ/WjZlnBJNWlZIHvuQ9RP+gBR33guA+ctOCMxVunHbuOKotCSB38JnLmFCnVcyGzkMYJU7h3BdcyYVzSNGS3Wpb23RuhE2fJCxZqsWQyOKOpYh0gvBFpmbHAmzhC3CEKCWdpXIshVDRj8Cnm+NRQ94bHk4ewufsDcNQHjvvASRecp2Jp0jJ0u6mts7GD0kyUuQ68Lmbv37x4OZx032U8D/Fww9Jg3MUjkc14vqiYsy3Ps61wwgG/K5GIwmDOTGgtsi2mjRzLPjdc8lgn4RwaAgEEd8TsTxaBYTy/xs3FDZMpLazjUEMiKhfrOxuG1tYrNlfwaOLw3FK5ejZOWM5TyWgH47li2t0FbjtAJERqI1MXCwcbkGPa1FNcF9Q1B7tSnjOEywR3UkMLWsDJ+qGJWMryhU4CH84bS/MSjrZ1/NJim+u1T2FGby3S+jQHijpg5gQLJoyirPlc1xSt6lwjDZ2yr+JVITZGdYwNy1FX3LIOhYYyYmEVxlq9LiK9KljwDndVLUTzBXrLy7YYQ2u48m3SgrcrsFppmkcsGB638N0GtRlWBZc0NQ2nvgXPCrSgTMQNMoOX3Wj7ID6dI8BULngeTIb1sxVRBY0Mf0cNOqOK7ZBxgxsVy0lUcy2PvsMkGLqt5B/vvt2omkZpX1IuwYAQjdmyqYMZC34FqLLWNxRTwQ7ad2arsXXinN+i5KTk4GVY5rYHmImAdIW0yfd+kVnb17oyCIkoWB7OuFZ9Aqh+My1uEGfNdZSYSFdiRVoiGcgQKLQImrqOmIlXeBsceTvQCtBP4IHUw0Vkcn3uvyIfXfLJJVfu4PzEJ6f48E8clse1xPQ0j8n5W/w5eO+5Y3Lhkr6fqW1RMZMEBYKjiJjPoTB29ypYuZhg2nRUyDM+JytRkgQdiHD9HE555BE/U8kwlhAjUggMVkQdURqce+T0yCNnI9f9G2XbUIlOGGkGAaEECSFVkRJT8bBoJap5/YJoQXAqA6WJEhmD//Z1IcEkDE5z+tXP7nACHybk45GPOJtfZ/fd/rom0wzdgVyRsqiPpIh441HrDbthOcmEMdvm7PMRsWY//vLJ+IlWRpBThT6lXsBb66hpZYQrIkrd+L6kq8H7V+P9RpVmBTqYsvk9P9nvw5TO0AtLvZ2Q6X0hBe5kqIxlY7F2LBv9hmwXKY9ACKpfk/uYrtbmt2b4MFNhPZi+oYpHBAPEJEO9Ju9MPZOqsUMl7exra/IH6g4y99tL25qcoXEC7u5hMP3BLD/EnIN39XpUHXrW5ACVGleK1apQTfl11oGW1dmLjlYklO5qmWdYfe8hehf3vTsXSPF7jqXA6iN9NI5NVaBElrmtmI4sMR3KmDPFef9gr/usqV4zJ+TS67Pk/yNT7r936tz3NqRGXYABNzQtmeoSsJ9v8OF4Q10wjSy5Tqo6p3lF4k057S0ZK3Tldurq6qEIqt3DWNxT37Yz1Jszic09vUmWDS73dLfpxdK0enOK0fTREpoOW/fpHp07JivxWjQm1RpkfDvDKkROPbe3axPPzTLTA8y6Q3Cf6PrLTyF0QXm+Oevovn8rXg8u3Uddes6l0t/StbcTj5aCxmq5byZHht5DF5gSOXn39leiIslYDoJ6x+RDLTMcDs3k9feM3kv3C6ev0fEOE/swsZ9+Yo8OE/swsX/Mie3/iBP7sKYc1pSdNWX0f64pRsc/rDaH1ebpV5vxYbX5qlYb/+lWm8OW9J9tSaNHzc4xnP6OFobHrYaj7+vSh9XwsBrurIbjb201NDqjwzp5WCefdp2sv33vfuPagpuvWKt/LNgSskhHQjLM2IgNI3UTOEhC1WZOa162C2vVfGZML1GZ9tJRKaUNcUNhkwCbaCAt+oIsEyi0lW6XiaxMNS/Stl1INRxMLxME1Zxmgov1xrLcssgYvXyWP3cQE/01+UfnpgAb9/4CTbTYdw==
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
 -s skirtDistance=10000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=45 -s fixHorrible=1 -s layer0extrusionWidth=440 -s moveSpeed=100 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=400 -s insetCount=2 -s downSkinCount=10000 -s multiVolumeOverlap=150 -g 49674 -s posx=125000 -s posy=125000 $
Loaded from disk in 14.336s
['changeZ', '0']
['changeZ', '0']
 -s supportXYDistance=700 -s insetXSpeed=50 -s retractionZHop=0 -s extruderOffset[3].X=0 -s extruderOffset[3].Y=0 -s postSwitchExtruderCode=;Switch between the current extruder and the next extruder, when printing with multiple extruders.
 -s retractionSpeed=40 -s filamentFlow=100 -s infillOverlap=15 -s inset0Speed=50 -s coolHeadLift=0 -s extrusionWidth=400 -s upSkinCount=10000 -s initialLayerSpeed=35 -s minimalLayerTime=5 -s infillSpeed=50 -s supportExtruder=-1 -s fanSpeedMax=100 -s supportType=1 -s enableCombing=0 -s fanSpeedMin=100 -s supportZDistance=150 -s supportEverywhere=0 -s filamentDiameter=1750 -s initialLayerThickness=300 -s supportAngle=-1 -s fanFullOnLayerNr=2 -s extruderOffset[1].X=0 -s extruderOffset[1].Y=21600 -s layerThickness=200 -s endCode=;End GCode
M84                         ;steppers off
;CURA_PROFILE_STRING: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
 -s minimalExtrusionBeforeRetraction=20 -s retractionMinimalDistance=4000 -s skirtMinLength=200000 -s objectSink=0 -s retractionAmount=1000 -s skinSpeed=50 -s skirtLineCount=5 -s startCode=M190 S70.000000
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
 -s skirtDistance=10000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=50 -s fixHorrible=1 -s layer0extrusionWidth=440 -s moveSpeed=100 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=400 -s insetCount=2 -s downSkinCount=10000 -s multiVolumeOverlap=150 -g 49674 -s posx=125000 -s posy=125000 $
G1 Z+0.5 E-5 X-20 Y-20 F5100 ;move Z up a bit and retract filament even more
M84                         ;steppers off
;CURA_PROFILE_STRING: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
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
 -s skirtDistance=10000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=50 -s fixHorrible=1 -s layer0extrusionWidth=440 -s moveSpeed=85 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=400 -s insetCount=2 -s downSkinCount=10000 -s multiVolumeOverlap=150 -g 49674 -s posx=125000 -s posy=125000 $
Loaded from disk in 14.290s
M84                         ;steppers off
;CURA_PROFILE_STRING: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
 -s minimalExtrusionBeforeRetraction=20 -s retractionMinimalDistance=4000 -s skirtMinLength=200000 -s objectSink=0 -s retractionAmount=4000 -s skinSpeed=50 -s skirtLineCount=5 -s startCode=M190 S70.000000
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
Loaded from disk in 14.227s
Optimize model 16.256s
Slicing model...
Layer count: 716
Sliced model in 24.726s
Generated layer parts in 13.057s
Generated inset in 134.863s
Generated up/down skin in 87.688s
['changeZ', '0']
['changeZ', '0']
M84                         ;steppers off
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
 -s skirtDistance=3000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=45 -s fixHorrible=1 -s layer0extrusionWidth=400 -s moveSpeed=70 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=2666 -s insetCount=2 -s downSkinCount=3 -s multiVolumeOverlap=150 -g 49674 -s posx=125000 -s posy=125000 $
M84                         ;steppers off
;CURA_PROFILE_STRING:eNrtWktv20YQvhJCf8QeEzRWSUqK4wi8JLV9SYoAdtHEF2JFrsStSS6xu7QsG/rv/Xb5ECVTqdMabR7ywTI/zszOznzzAOSUrpgME8YXiQ7coe8saZqGOuHRdc6UAvTKkUxLGmku8pDldJay4FKWzFEi5XGYWgPbCnMOGzHLFderwHNdJxd3dykLFb9jEBg7heS5DlXBWByMJ/WjZlnBJNWlZIHvuQ9RP+gBR33guA+ctOCMxVunHbuOKotCSB38JnLmFCnVcyGzkMYJU7h3BdcyYVzSNGS3Wpb23RuhE2fJCxZqsWQyOKOpYh0gvBFpmbHAmzhC3CEKCWdpXIshVDRj8Cnm+NRQ94bHk4ewufsDcNQHjvvASRecp2Jp0jJ0u6mts7GD0kyUuQ68Lmbv37x4OZx032U8D/Fww9Jg3MUjkc14vqiYsy3Ps61wwgG/K5GIwmDOTGgtsi2mjRzLPjdc8lgn4RwaQlrCidmfLALDeH6Nm4sbJlNaWMehhkRULtZ3Pm6NV2Su0NHE4bllcvVsfLCUp5LRDsZzxbS7C9x2gEiI1AamrhUOMiDFtCmnuK6naw5ypTxniJaJrV9DC1oEI3O6fWoilrJ8oROwyhxhjM1L+NpW8kuLVU6YiLRPYUZvLdK6NQeKSgBDazBhFIXN57omaVXpGonoFH4VsgqxYaqjbHiOyuKWdyg1FBILq0jW6nUZ6VXBgne4rmohmi/QXV625Rhaw5Vvkxa8XYHXStM8YsHwuIXvNqjNsSq4pKlpOfUteFagCWUibpAZvNwKOKhP5wgxlQueB5Nh/WxFVEEjw+BRg86oYjt03OBGxbIS9VzLo/MwCY5uK/nHu283qqZV2peUS5AgRGu2hOpgxoJfAaqs9Q3LVLCD9p3ZamydOOe3KDopOagZlrntAmYmIF0hbfK9X2TWdrauDEIiCpaHM65VnwDq38yLG8RZcx0lJtKVWJGWSAYyBAotgqayI2biFd4GR94OtAL0E3gg9XARmVyf+6/IR5d8csmVOzg/8ckpPvwTh+VxLTE9zWNy/hZ/Dt577phcuKTvZ2qbVMwkQYHgKCLmcyiM3b0KVi4mmDcdFfKMz8lKlCRBDyJcP4dTHnnEz1QyDCbEiBQCoxVRR5QG5x45PfLI2ch1/0bZtlSiE0aaUUAoQUJIVaTEVDwsWolqYr8gWhCcykBpokTG4L99XUgwCaPTnH71szucwIcJ+XjkI87m19l9t8OuyTRDdyBXpCzqIyki3njUesNuWE4yYcy2Oft8RKzZj798Mn6ilRHkVKFPqRfw1jpqWhnhiohSN74v6Wrw/tV4v1GlWYEOpmx+z0/2+zClM/TCUm8nZHpfSIE7GSpj3VisHctGvyHbRcojEILq1+Q+pqu1+a0ZPsxgWA+mb6jiEcEMMclQr8k7U8+kauxQSTsb25r8gbqDzP322rYmZ2icgLubGEx/MOsPMefgXb0gVYeeNTlApcaVYrUsVHN+nXWgZXX2oqMVCaW7WuYZVt97iN7Ffe/WBVL8nmMtsPpIH41jUxUokWVuK6YjS0yHMuZMcd4/2Ow+a6rXzAm59Pos+f/IlPvvnTr3vQ2pURdgwA1NS6a6BOznG3w43lAXTCNLrpOqzmlekXhTTntLxgpduZ26unoogmr3MBb31LftDPXuTGJzT2+SZYPLPd1terE0rd6cYjR9tISmw9Z9ukfnjslKvBaNSbUIGd/OfPTAU8/t7drEc7PM9ACz7hDcJ7r+8lMIXVCeb846uu/fi9eDS/dRl55zqfS3dO3txKOloLFa7pvJkaH30AWmRE7evf2VqEgyloOg3jH5UMsMh0Mzef09o/fS/cLpa3S8w8Q+TOynn9ijw8Q+TOwfc2L7P+LEPqwphzVlZ00Z/Z9ritHxD6vNYbV5+tVmfFhtvqrVxn+61eawJf1nW9LoUbNzDKe/o4Xhcavh6Pu69GE1PKyGO6vh+FtbDY3O6LBOHtbJp10n62/fu9+4tuDmK9bqHwu2hCzSkZAMMzZiw0jdBA6SULWZ05qX7cJaNZ8Z00tUpr10VEppQ9xQ2CTAJhpIi74gywQKbaXbZSIrU82LtG0XUg0H08sEQTWnmeBivbEstywyRi+f5c8dxER/Tf7RuSnAxr2/AH1J2Ns=
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
 -s skirtDistance=3000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=45 -s fixHorrible=1 -s layer0extrusionWidth=400 -s moveSpeed=70 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=400 -s insetCount=2 -s downSkinCount=10000 -s multiVolumeOverlap=150 -g 49674 -s posx=125000 -s posy=125000 $
Loaded from disk in 14.196s
M84                         ;steppers off
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
Loaded from disk in 14.461s
M84                         ;steppers off
;CURA_PROFILE_STRING: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
 -s minimalExtrusionBeforeRetraction=20 -s retractionMinimalDistance=4000 -s skirtMinLength=150000 -s objectSink=0 -s retractionAmount=1000 -s skinSpeed=45 -s skirtLineCount=5 -s startCode=M190 S70.000000
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '3']
['changeZ', '3']
['changeZ', '3']
['changeZ', '3']
['changeZ', '3']
['changeZ', '4']
['changeZ', '4']
['changeZ', '4']
['changeZ', '4']
['changeZ', '4']
['changeZ', '5']
['changeZ', '5']
['changeZ', '5']
['changeZ', '5']
['changeZ', '5']
['changeZ', '6']
['changeZ', '6']
['changeZ', '6']
['changeZ', '6']
['changeZ', '6']
['changeZ', '7']
['changeZ', '7']
['changeZ', '7']
['changeZ', '7']
['changeZ', '7']
['changeZ', '8']
['changeZ', '8']
['changeZ', '8']
['changeZ', '8']
['changeZ', '8']
['changeZ', '9']
['changeZ', '9']
['changeZ', '9']
['changeZ', '9']
['changeZ', '9']
['changeZ', '10']
['changeZ', '10']
['changeZ', '10']
['changeZ', '10']
['changeZ', '10']
['changeZ', '11']
['changeZ', '11']
['changeZ', '11']
['changeZ', '11']
['changeZ', '11']
['changeZ', '12']
['changeZ', '12']
['changeZ', '12']
['changeZ', '12']
['changeZ', '12']
['changeZ', '13']
['changeZ', '13']
['changeZ', '13']
['changeZ', '13']
['changeZ', '13']
['changeZ', '14']
['changeZ', '14']
['changeZ', '14']
['changeZ', '14']
['changeZ', '14']
['changeZ', '15']
['changeZ', '15']
['changeZ', '15']
['changeZ', '15']
['changeZ', '15']
['changeZ', '16']
['changeZ', '16']
['changeZ', '16']
['changeZ', '16']
['changeZ', '16']
['changeZ', '17']
['changeZ', '17']
['changeZ', '17']
['changeZ', '17']
['changeZ', '17']
['changeZ', '18']
['changeZ', '18']
['changeZ', '18']
['changeZ', '18']
['changeZ', '18']
['changeZ', '19']
['changeZ', '19']
['changeZ', '19']
['changeZ', '19']
['changeZ', '19']
['changeZ', '20']
['changeZ', '20']
['changeZ', '20']
['changeZ', '20']
['changeZ', '20']
['changeZ', '21']
['changeZ', '21']
['changeZ', '21']
['changeZ', '21']
['changeZ', '21']
['changeZ', '22']
['changeZ', '22']
['changeZ', '22']
['changeZ', '22']
['changeZ', '22']
['changeZ', '23']
['changeZ', '23']
['changeZ', '23']
['changeZ', '23']
['changeZ', '23']
['changeZ', '24']
['changeZ', '24']
['changeZ', '24']
['changeZ', '24']
['changeZ', '24']
['changeZ', '25']
['changeZ', '25']
['changeZ', '25']
['changeZ', '25']
['changeZ', '25']
['chang
Thoughts?
    The issue is that I'm currently using a Printrbot Metal Plus and this was the version they link to on their site. From what I've read, the newer versions of Cura no longer support this printer. Is there a way to get it working with the newest version?
    I went through all the settings and think I have pretty much everything locked in, but is there any Pronterface UI option for the prints? I want to make sure that I can set the probe offset, etc before starting my print.
    Posted · pythonw.exe stopped working, Windows 7
    So from what I'm reading it looks like Pronterface UI isn't an option anymore. Is there another way of editing the probe offset, etc in the new version of Cura?
          • Heart
        • 7 replies
